Here is the message (i removed the first path):
java.nio.file.DirectoryNotEmptyException: /Users/...
at java.base/sun.nio.fs.UnixFileSystemProvider.implDelete(Unknown Source)
at java.base/sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(Unknown Source)
at java.base/java.nio.file.Files.deleteIfExists(Unknown Source)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.forceDeleteIfExists(DeletingFileVisitor.java:68)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.postVisitDirectory(DeletingFileVisitor.java:57)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.postVisitDirectory(DeletingFileVisitor.java:31)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:106)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:112)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:115)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
