What have I done:
- i work with Linux: Ubuntu 20.04 (LTS)
- connect to the WebDAV service from the internet via Nautilus
- connect to the server: davs-://-webdav-smartdrive-web-de/
- user: xxxxxx
- password: yyyyy
- all data is visible in the Nautilus application
- start the application Cryptomator as AppImage
- i don’t have a select button for the web applications (DropBox, Web.de, etc))
- create a new vault (name and password)
- select the WebDAV service in the file selection window
- the files are created at the WebDAV service, everything looks good
- then the error message appears, see below
- settings of the Cryptomator:
- drive: WebDAV
- WebDAV port: 42427
- WebDAV scheme: dav-://-(Gnome, Nautilus, …)
java.nio.file.FileSystemException: /run/user/1000/gvfs/dav:host=webdav-smartdrive-web-de,ssl=true/xxyy/d/4F/ZSQVE55X7UI2YUIQIJCPUMUVNHZQB4/kimB4XlLA10IamfYlOBB18E5BeknJ7jCNtJ0HXWN.c9r: Vorgang wird nicht unterstützt
at java.base/sun.nio.fs.UnixFileAttributeViews$Basic.setTimes(Unknown Source)
at org.cryptomator.cryptofs.ch.CleartextFileChannel.persistLastModified(CleartextFileChannel.java:238)
at org.cryptomator.cryptofs.ch.CleartextFileChannel.implCloseChannel(CleartextFileChannel.java:306)
at java.base/java.nio.channels.spi.AbstractInterruptibleChannel.close(Unknown Source)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.initializeVault(CreateNewVaultPasswordController.java:175)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.lambda$showSuccessScene$5(CreateNewVaultPasswordController.java:151)
at org.cryptomator.ui.common.Tasks.lambda$create$0(Tasks.java:34)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:140)
Cryptomator-Log:
17:59:44.232 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.11 on Linux 5.4.0-62-generic (amd64)
17:59:44.596 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
17:59:46.799 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
18:01:09.881 [DBus Worker Thread-2] INFO o.f.secret.handlers.SignalHandler - Received signal Collection.ItemCreated: /org/freedesktop/secrets/collection/session/1
18:11:40.140 [JavaFX Application Thread] WARN o.c.u.a.CreateNewVaultLocationController - Can not use already existing vault path /run/user/1000/gvfs/dav:host=webdav.smartdrive.web.de,ssl=true/xy
18:13:12.820 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
18:13:12.822 [main] INFO org.cryptomator.launcher.Cryptomator - UI shut down
