Win 10 Pro 2004 (build 19041.630). Latest version of Cryptomator mounted via Dokany. Vault is located in Google Drive and synced via Google’s Sync & Backup application.
I like backup the contents of my unencrypted vault on a regular basis. My process is to use 7zip to archive the contents of the vault into a .ZIP file on my C:\ drive before copying it to a USB HDD. I ran into a file access failure with a specific file in my vault. The interesting thing is that I have this access failure if I try to copy this unencrypted file to my C: drive as well.
Log contents:
17:28:29.095 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.8 on Windows 10 10.0 (amd64)
17:28:29.945 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
17:28:29.975 [JavaFX Application Thread] INFO org.cryptomator.jni.FunctionsLoader - loaded WinFunctions.dll
17:28:34.963 [JavaFX Application Thread] WARN o.c.keychain.KeychainManager - LOAD
17:28:36.969 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.8, lastest version: 1.5.8
17:28:41.639 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany version: 140
17:28:41.640 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
17:28:44.643 [App Background Thread 004] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'MyVault' succeeded.
17:29:12.165 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed MyVault
17:31:30.320 [Thread-113943] WARN o.c.frontend.dokany.ReadWriteAdapter - (7673) readFile(): IO error while reading file /Telegram/tdata/user_data/cache/0/binlog.
java.io.IOException: org.cryptomator.cryptolib.api.AuthenticationFailedException: Authentication of chunk 8 failed.
at org.cryptomator.cryptofs.fh.ChunkCache.get(ChunkCache.java:67)
at org.cryptomator.cryptofs.ch.CleartextFileChannel.readLocked(CleartextFileChannel.java:109)
at org.cryptomator.cryptofs.ch.AbstractFileChannel.read(AbstractFileChannel.java:155)
at org.cryptomator.cryptofs.ch.AbstractFileChannel.read(AbstractFileChannel.java:139)
at org.cryptomator.frontend.dokany.OpenFile.readNext(OpenFile.java:95)
at org.cryptomator.frontend.dokany.OpenFile.read(OpenFile.java:49)
at org.cryptomator.frontend.dokany.ReadWriteAdapter.readFile(ReadWriteAdapter.java:335)
at com.dokany.java.DokanyOperationsProxy$ReadFileProxy.callback(DokanyOperationsProxy.java:86)
at jdk.internal.reflect.GeneratedMethodAccessor46.invoke(Unknown Source)
at com.sun.jna.CallbackReference$DefaultCallbackProxy.invokeCallback(CallbackReference.java:520)
at com.sun.jna.CallbackReference$DefaultCallbackProxy.callback(CallbackReference.java:551)
Caused by: org.cryptomator.cryptolib.api.AuthenticationFailedException: Authentication of chunk 8 failed.
at org.cryptomator.cryptolib.v1.FileContentCryptorImpl.decryptChunk(FileContentCryptorImpl.java:71)
at org.cryptomator.cryptofs.fh.ChunkLoader.load(ChunkLoader.java:38)
at org.cryptomator.cryptofs.fh.ChunkCache.loadChunk(ChunkCache.java:40)
at com.google.common.cache.CacheLoader$FunctionToCacheLoader.load(CacheLoader.java:165)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3529)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2278)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2155)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2045)
at com.google.common.cache.LocalCache.get(LocalCache.java:3951)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3974)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4958)
at org.cryptomator.cryptofs.fh.ChunkCache.get(ChunkCache.java:57)
Any ideas on what’s causing this access failure? For what it’s worth, Telegram runs just fine out of my vault. I’ve never encountered this problem when attempting to run Telegram.
I said that I don’t have an issue with running Telegram out of my vault. That is correct. However, in looking at today’s log file, it looks like a similar error does appear when attempting to run Telegram:
09:14:54.491 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.8 on Windows 10 10.0 (amd64)
09:14:55.757 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
09:14:55.797 [JavaFX Application Thread] INFO org.cryptomator.jni.FunctionsLoader - loaded WinFunctions.dll
09:15:03.382 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.8, lastest version: 1.5.8
09:15:14.280 [JavaFX Application Thread] WARN o.c.keychain.KeychainManager - LOAD
09:15:21.944 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany version: 140
09:15:21.944 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
09:15:24.949 [App Background Thread 004] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'MyVault' succeeded.
09:32:52.004 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed MyVault
09:33:16.470 [Thread-7960] WARN o.c.frontend.dokany.ReadWriteAdapter - (1615) readFile(): IO error while reading file /Telegram/tdata/user_data/cache/0/binlog.
... 12 common frames omitted
09:33:16.482 [Thread-8000] WARN o.c.frontend.dokany.ReadWriteAdapter - (1615) readFile(): IO error while reading file /Telegram/tdata/user_data/cache/0/binlog.
