SO MANY PEOPLE on my team are getting a plethora of error codes when they go to open the vaults before it prompts for a password. A lot of people can access it just fine. It is always different people each round, on both mac and PC. Googling the error codes are yielding no results. I am not savy enough to understand a lot of these other error code posts and solutions to know how to potentially even look into those on my end. Can someone help me in an eli5 way?
I cant upload the attachments and there are 6 different ones in here. i dont know which is which or what any of them mean so ill paste them as 6 different replies
i tried pasting the others but it wont let me due to some kind of link error.
this is just from one person with the error codes they got. i got different ones from the other team mates but with the same prefix of TB89
08:09:54.451 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.10 on Mac OS X 12.3.1 (aarch64)
08:09:54.483 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /Users/ei-mac019/Library/Application Support/Cryptomator/ipc.socket
08:09:54.839 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX runtime started after 1558ms
09:26:46.286 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:26:58.310 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:39:55.111 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:39:56.472 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-conclave' failed.
09:39:56.474 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
java.nio.file.NoSuchFileException: /Volumes/GoogleDrive/Shared drives/Amazon Studios/Vox Machina S2/Assets/01 From Client/chroma-conclave/c/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
at java.base/sun.nio.fs.UnixFileSystemProvider.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createAndCheckIsDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectories(Unknown Source)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.determineSupportedCiphertextFileNameLength(FileSystemCapabilityChecker.java:136)
at org.cryptomator.cryptofs@2.4.1/org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.determineSupportedCiphertextFileNameLength(FileSystemCapabilityChecker.java:113)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:111)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.unlock(Vault.java:148)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
09:40:04.960 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-conclave' failed.
09:40:04.961 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
09:40:20.587 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:40:21.975 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-cries' failed.
09:40:21.975 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
java.nio.file.NoSuchFileException: /Volumes/GoogleDrive/Shared drives/Amazon Studios/Vox Machina S2/Assets/01 From Client/chroma-cries/c/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
09:53:54.774 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:13.667 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:15.611 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:22.164 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:26.169 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:36.743 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:41.430 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:45.176 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:48.457 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:54:51.588 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:55:10.428 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:55:11.228 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-conclave' failed.
09:55:11.228 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
09:57:16.111 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:57:16.940 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-cries' failed.
09:57:16.940 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
11:00:47.525 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
11:00:50.891 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
11:01:22.849 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
11:01:23.103 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-cries' failed.
11:01:23.103 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
09:27:38.216 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:28:21.899 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:28:22.272 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-cries' failed.
09:28:22.272 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
09:28:39.095 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
09:28:39.951 [JavaFX Application Thread] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'chroma-conclave' failed.
09:28:39.952 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
13:18:10.655 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
13:18:40.139 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
13:18:43.122 [JavaFX Application Thread] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
13:18:44.127 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
13:18:44.128 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/ei-mac019/Library/Application Support/Cryptomator/settings.json
i dont know how to do that. ill go ahead and delete them since you saw them and we are working past that part. thank you for the heads up.
everything is on google drive under those same path methods and directory lengths. its only some that refuse to open and for random projects and random people each time.
