Error Code H1VR:BRG5:BRG5
Hi everybody.
As you can see from the subject, I am having a problem with Cryptomator.
I have been using Cryptomator for a long time without issues, but today suddenly I’m not able to access my encrypted vaults.
When I try to access any one of them, I get this error:
java.lang.UnsatisfiedLinkError: no fuse3 in java.library.path: :/tmp/.mount_cryptokdfOAn/lib/app:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
	at java.base/java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.base/java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.base/java.lang.System.loadLibrary(Unknown Source)
	at org.cryptomator.jfuse.linux.amd64@0.7.1/org.cryptomator.jfuse.linux.amd64.LinuxFuseBuilder.build(LinuxFuseBuilder.java:42)
	at org.cryptomator.frontend.fuse@5.0.3/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:123)
	at org.cryptomator.desktop@1.16.0-beta1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172)
	at org.cryptomator.desktop@1.16.0-beta1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:179)
	at org.cryptomator.desktop@1.16.0-beta1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:108)
	at org.cryptomator.desktop@1.16.0-beta1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:82)
	at org.cryptomator.desktop@1.16.0-beta1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:37)
	at javafx.graphics@23.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Cryptomator tried to be helpful and suggested me a solution here.
Unfortunately, even by following the suggestions in that article I cannot fix the problem (you can see my comment at the end of that github discussion).
I even tried installing the Cryptomator flatpak package as suggested, but the situation is even worse: the flatpak package somehow cannot recognize vaults with names which contain special characters (in my case, an Italian accented char).
Next, I tried to install the 1.16.0-beta1 appimage, but the problem was still there.
I am out of ideas, and I need access to my data.
Fortunately, I can still access my data by using Cryptomator on Android, but that’s very uncomfortable.
Please please help.
Best regards
Cris
Forgot to add some important information.
First of all, here are my system info:
Operating System: openSUSE Tumbleweed 20250329
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.2
Kernel Version: 6.13.8-1-default (64-bit)
Graphics Platform: Wayland
Next important thing: I do have the fuse3 library in the search path:
cris ~ > ll /usr/lib64/*fuse3*
-rwxr-xr-x 1 root root 276680 26 mar 00.09 /usr/lib64/libfuse3.so.3.17.1
lrwxrwxrwx 1 root root     18 26 mar 00.09 /usr/lib64/libfuse3.so.4 -> libfuse3.so.3.17.1
Hope this helps…
Cris
Welcome to the Cryptomator community, :slightly_smiling_face:
i edited my post in the disscussion to make it clearer what the workaround is. It is marked as the disscussion solution.
Thank you @infeo for your clarification.
Unfortunately, as you can see in my comment in the discussion, there’s no libfuse3-3 available for openSUSE Tumbleweed, at least not in the official repositories.
However, your solution gave me an idea: I went to https://software.opensuse.org to look for libfuse3-3.
I downloaded the library in its version for Tumbleweed, and now Cryptomator works!!
Thank you!!
Cris
P.S. I hope BTW that Cryptomator will adapt soon to the new releases of libfuse3
