Hi, I tried to decrypt vault and get an error message. Can anybody help me?
Error Code B52N:J65U:J65U
java.io.IOException: Operation timed out
at java.base/sun.nio.ch.UnixFileDispatcherImpl.read0(Native Method)
at java.base/sun.nio.ch.UnixFileDispatcherImpl.read(Unknown Source)
at java.base/sun.nio.ch.IOUtil.readIntoNativeBuffer(Unknown Source)
at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
at java.base/java.nio.file.Files.read(Unknown Source)
at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
at java.base/java.nio.file.Files.readString(Unknown Source)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.VaultConfigCache.readConfigFromStorage(VaultConfigCache.java:61)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.VaultConfigCache.reloadConfig(VaultConfigCache.java:30)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.VaultListManager.create(VaultListManager.java:100)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.AbstractList$RandomAccessSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.toArray(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.toList(Unknown Source)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.VaultListManager.addAll(VaultListManager.java:83)
at org.cryptomator.desktop@1.9.1/org.cryptomator.common.vaults.VaultListManager.<init>(VaultListManager.java:52)
at org.cryptomator.desktop@1.9.1/org.cryptomator.launcher.DaggerCryptomatorComponent$CryptomatorComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:9337)
at dagger@2.45/dagger.internal.DoubleCheck.get(DoubleCheck.java:47)
at org.cryptomator.desktop@1.9.1/org.cryptomator.launcher.DaggerCryptomatorComponent$FxApplicationComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:8775)
at org.cryptomator.desktop@1.9.1/org.cryptomator.launcher.DaggerCryptomatorComponent$FxApplicationComponentImpl$SwitchingProvider.get(DaggerCryptomatorComponent.java:8762)
at org.cryptomator.desktop@1.9.1/org.cryptomator.launcher.DaggerCryptomatorComponent$FxApplicationComponentImpl.application(DaggerCryptomatorComponent.java:8734)
at org.cryptomator.desktop@1.9.1/org.cryptomator.launcher.Cryptomator$MainApp.start(Cryptomator.java:135)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$9(Unknown Source)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runAndWait$12(Unknown Source)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(Unknown Source)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(Unknown Source)
at javafx.graphics/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(Unknown Source)
