Error Code 6PHE:T90H:T90H
org.cryptomator.cryptofs.VaultConfigLoadException: Failed to parse config:
at org.cryptomator.cryptofs@2.4.2/org.cryptomator.cryptofs.VaultConfig.decode(VaultConfig.java:115)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.VaultConfigCache.readConfigFromStorage(VaultConfigCache.java:62)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.VaultConfigCache.reloadConfig(VaultConfigCache.java:30)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.VaultListManager.create(VaultListManager.java:100)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.VaultListManager.lambda$add$0(VaultListManager.java:65)
at java.base/java.util.Optional.orElseGet(Unknown Source)
at org.cryptomator.desktop@1.6.14/org.cryptomator.common.vaults.VaultListManager.add(VaultListManager.java:64)
at org.cryptomator.desktop@1.6.14/org.cryptomator.ui.fxapp.AppLaunchEventHandler.addOrRevealVault(AppLaunchEventHandler.java:73)
at java.base/java.lang.Iterable.forEach(Unknown Source)
at org.cryptomator.desktop@1.6.14/org.cryptomator.ui.fxapp.AppLaunchEventHandler.lambda$handleLaunchEvent$0(AppLaunchEventHandler.java:61)
at javafx.graphics@18.0.1/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:457)
at javafx.graphics@18.0.1/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:456)
at javafx.graphics@18.0.1/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
at javafx.graphics@18.0.1/com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at javafx.graphics@18.0.1/com.sun.glass.ui.win.WinApplication.lambda$runLoop$3(WinApplication.java:184)
my vault.cryptomator、vault.cryptomator.2EAC93DC.bkup 、masterkey.cryptomator、masterkey.cryptomator.F6B7588B.bkup are empty. When I use binary to view everything, either 0 or–
.I want to know, can the data still be found
