Macos: 13.4
Cryptomator: 1.9.0 Intel
Fuse-T: 1.0.19
Error Code 4VHF:Q9JM:II79
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_new failed
at org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.MacFuseMountProvider$MacFuseMountBuilder.mount(MacFuseMountProvider.java:124)
at org.cryptomator.desktop@1.9.0/org.cryptomator.common.mount.Mounter.mount(Mounter.java:134)
at org.cryptomator.desktop@1.9.0/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)
at org.cryptomator.desktop@1.9.0/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.9.0/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.9.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.9.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_new failed
at org.cryptomator.jfuse.mac@0.5.1/org.cryptomator.jfuse.mac.FuseImpl.mount(FuseImpl.java:37)
at org.cryptomator.jfuse.api@0.5.1/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:127)
at org.cryptomator.frontend.fuse@3.0.0/org.cryptomator.frontend.fuse.mount.MacFuseMountProvider$MacFuseMountBuilder.mount(MacFuseMountProvider.java:121)
... 13 more
