On automatic startup an error occurs for all vaults. I updated Fuse for Mac and Cryptomator to the newest version. I can unlock the Vaults after dismissing the error. Any ideas?
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: java.util.concurrent.TimeoutException: fuse init() not called after 10000 milliseconds.
at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:48)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
... 12 more
Caused by: java.util.concurrent.TimeoutException: fuse init() not called after 10000 milliseconds.
at org.cryptomator.frontend.fuse.ReadOnlyAdapter.awaitInitCall(ReadOnlyAdapter.java:290)
at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:39)
... 14 more
