Dropbox and File Provider for MacOS
My Dropbox desktop app updated to add ‘File Provider for MacOS’ storage. This makes some changes, including the OS deciding which files are stored local and which files download “on the fly” as accessed.
Is Cryptomator compatible with File Provider for MacOS? Is there something special I need to do to make it work properly? I noticed that when you right click on a folder, you have a new option that says “Make available offline.” I assume this option always keep a local copy of the folder. I assume, as a minimum, I would need to do that. Is there anything else I need to worry about?
