When i unlock the vault and reveal it, cryptomator doesn’t moun the vault in .local/share/Cryptomator/mnt, it mounts the vault in the localhost.
INFO o.cryptomator.ui.common.VaultService - Vault mounted at http://localhost:42427/PrYTd-eEC7Rm
So, i can’t access my vault.
infeo
2
you need to change the volume type Cryptomator uses to FUSE:
0. Lock all vaults
- Open in Cryptomator the general preferences
- Switch to “Virtual Volume” tab
- Select FUSE in the dropdown menu
Now all your vaults will be mounted in the desired directory.
