Does cryptomator work on chrome os?
Not official supported, but some users reported that it works with some restrictions. Just search for „chrome“ in this board.
There are two versions that work on Chrome OS:
Just download the Android application from Play Store, it works roughly the same as on a phone
Enable Linux Beta in Chrome OS Settings and install the AppImage for Debian Linux that you typically start from the command line terminal. It works just like the desktop Linux/Mac/Windows version. If you want to access files from Google Drive, you would need to share the Drive folder with Linux by right-clicking the folder in the Chrome OS file manager.
