Does cryptomator work on apple silicon?
Planing to buy an apple silicon macbook - is cryptomator working reliably?
I like to use search parameters under windows like NOT kind:folder and the cryptomator vault always crashed until I changed it to winfsp (local drive) - only winfsp didn‘t work I think because of the interpretation of windows as a network storage but I‘m not sure about that.
The big question: Does anyone know if that also works with cryptomator vaults on a macbook with an apple silicon chip?
Thanks for the information and the help.
Yes - i use it on a M1 and a M4pro Macbook Pro. The vaults are stable so far - but i dont use it very intense to be honest.
I only dislike that the unlocked vaults are not displayed are drives or so but instead a subfolder or “localhost“. That makes it impossible to add the vault or subfolders them to the sidebar.
Thank you for your answer :slight_smile: Do you use Fuse-T or WebDav as your mounting option? And how large ist the data size that you store in your vaults?
