Up front: I have -not- yet installed Cryptomator. Am first checking around before doing so.
Am using Windows 10 x64, have an Outlook.com account and use OneDrive.
Question: does Cryptomator automatically lock the fault after some time?
Similar to Microsoft’s Personal Vault, which closes after 20 minutes.
Thanks. No, personally I do -not- want it. The Microsoft Personal Vault has it and it makes it unusable: when busy with things, the vault locks in the background. Pretty annoying. I think if Cryptomator were to introduce this, then I would then recommend it as an option only, keeping the current way as default.
Thanks again.
