Hi there,
as a newbie, i set up my vault in the folder “folder1\vaultfolder“ and then went to the settings of the vault and set the mount point to “folder1“. Apparently this is not a smart thing to do, because after unlocking the vault the desktop app hung up and my laptop froze after a minute.
Is there any way to have the desktop app detect and prevent the user from setting this up?
If not, maybe there should be a warning above the field for the mount path in the settings.
Anyway, in general i really like the use and speed of the cryptomator desktop app ![]()
Max
