I am trying to install .deb package, (or a non AppImage package) on Debian Bookworm; and I am not able to to install CryptoMator.
sudo add-apt-repository ppa:sebastian-stenzel/cryptomator
sudo apt update
The process ends up with:
E: The repository 'https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
To overcome this, I added [trusted=yes] to the source:
sudo nano /etc/apt/sources.list.d/sebastian-stenzel-ubuntu-cryptomator-bookworm.list
Thus:
deb https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu/ bookworm main
# deb-src https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu/ bookworm main
becomes this:
deb [trusted=yes] https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu/ bookworm main
However, running the update once again, I do get this:
Ign:14 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main amd64 DEP-11 Metadata
Ign:15 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main DEP-11 48x48 Icons
Ign:16 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main DEP-11 64x64 Icons
Ign:18 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main DEP-11 128x128 Icons
Ign:10 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main all Packages
Ign:11 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main amd64 Packages
Ign:12 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main all DEP-11 Metadata
Err:11 https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu bookworm/main amd64 Packages
404 Not Found [IP: 185.125.190.52 443]
Fetched 18.4 kB in 36s (508 B/s)
Reading package lists... Done
E: Failed to fetch https://ppa.launchpadcontent.net/sebastian-stenzel/cryptomator/ubuntu/dists/bookworm/main/binary-amd64/Packages 404 Not Found [IP: 185.125.190.52 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Of course, same lines appear when I do try to install Cryptomator:
sudo apt update && apt install cryptomator
Is there a Debian Bookworm package? Or there is not? What am I missing here?
Thanx
