I’m having an issue with Cryptomator on MacOS Catalina 10.15.6.
I initially set this up on my windows 10 pc, then I purchased a macbook and synced the google drive to my macbook. Now I’m trying to unlock the drive and it throws an error: Unable to contact localhost.
So I do nano /etc/hosts and look and everything is as it should be per another post I had read.
Unsure how to get this working on my macbook. Here is a copy of the code it threw after clicking ok.
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:65: execution error: An error of type -5014 has occurred. (-5014)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:65)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:49)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:65: execution error: An error of type -5014 has occurred. (-5014)
at org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter.mount(MacAppleScriptMounter.java:50)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:62)
... 12 more
