After uninstalling the app from Windows 10. cryptomator-vault TCP connections are still being made if seen from a network monitor. Why is that? And how to remove it?
This means its not completely uninstalled
cryptomator-vault is merely an alias for 127.0.0.1 that gets written to the hosts file. Maybe other software uses loopback connections and for some reason it gets reported as said alias?
Otherwise I have no idea. If you stop and uninstall Cryptomator, connections to its TCP socket are no longer possible, so this can’t be anything but false monitoring.
Yes, that was it. Many thanks!
