Cryptomator using up almost entire disk but actual disk usage is tiny
I have a Cryptomator vault on macOS Sonoma which is around 50 GB. I sync it using Dropbox but I have the whole vault downloaded locally. For some reason it’s reported as 1.91 TB but actual data usage of the raw vault before it’s mounted is like 50 GB…
adam@Adams-MacBook-Pro / % df -h
Filesystem                                    Size    Used   Avail Capacity iused ifree %iused  Mounted on
/dev/disk3s1s1                               1.8Ti    12Gi    78Gi    14%    404k  821M    0%   /
devfs                                        302Ki   302Ki     0Bi   100%    1.0k     0  100%   /dev
/dev/disk3s6                                 1.8Ti   3.0Gi    78Gi     4%       3  821M    0%   /System/Volumes/VM
/dev/disk3s2                                 1.8Ti    11Gi    78Gi    13%    1.6k  821M    0%   /System/Volumes/Preboot
/dev/disk3s4                                 1.8Ti   637Mi    78Gi     1%     314  821M    0%   /System/Volumes/Update
/dev/disk1s2                                 500Mi   6.0Mi   480Mi     2%       1  4.9M    0%   /System/Volumes/xarts
/dev/disk1s1                                 500Mi   6.2Mi   480Mi     2%      34  4.9M    0%   /System/Volumes/iSCPreboot
/dev/disk1s3                                 500Mi   3.0Mi   480Mi     1%      88  4.9M    0%   /System/Volumes/Hardware
/dev/disk3s5                                 1.8Ti   1.7Ti    78Gi    96%    3.3M  821M    0%   /System/Volumes/Data
map auto_home                                  0Bi     0Bi     0Bi   100%       0     0     -   /System/Volumes/Data/home
/dev/disk3s7                                 1.8Ti   4.2Gi    78Gi     6%    1.7k  821M    0%   /Library/Synology/ActiveBackupforBusiness/ActiveBackupforBusiness_Reserved
/dev/disk2s1                                 5.0Gi   1.7Gi   3.2Gi    36%      62   34M    0%   /System/Volumes/Update/SFR/mnt1
/dev/disk3s1                                 1.8Ti    12Gi    78Gi    14%    404k  821M    0%   /System/Volumes/Update/mnt1
//Guest:@fuse-t-0._smb._tcp.local/Datasets   1.8Ti   1.7Ti    78Gi    96%    467M   21M   96%   /Users/adam/Library/Application Support/Cryptomator/mnt/Datasets
Any help or ideas? I recently also installed a Synology backup tool which I believe does a snapshot/image in macOS (ActiveBusinessBackup). I think it could be related to that. I should have over 1 TB of free disk space, not 80 GB…
Solved this, it was my Synology backup software (ABB) which was creating huge snapshots. That along with Time Machine had huge AFPS snapshots. Not related to Cryptomator… hope that helps someone.
