Cryptomator Used on Local Drive
Are there any reasons for concern when using Cryptomator for encrypting files on a local drive (C:)? I have set up three vaults in My Documents (Windows 10) and it appears to be working well. But, I am a very new user and maybe overlooking potential problems.
Would appreciate your knowledgeable insight / wisdom.
Regards and thank you.
Cryptomator is designed and optimised for online storage.
There are reasons why you should consider a tool that’s designed for local encryption.
