Ich nutze Linux XUbuntu 22.04. Mein Thunderbird lager die Emails in einem Container. Thunderbird reagiert nicht und ich kann den Container nicht schließen. Ein Fehler : Error Code 8SBH:MUNN:MUNN , habe ich auf GitHub gefunden. Kann aber als DAU damit nichts anfangen. Bräuchte irgendwie Hilfe.
Danke
I use Linux XUbuntu 22.04. My Thunderbird stores the emails in a container. Thunderbird does not respond and I can not close the container. An error : Error Code 8SBH:MUNN:MUNN , I found on GitHub. But as a DAU I can’t do anything with it. Need help somehow.
Thanks
Hier eine Fehlermeldung:
Error Code 8SBH:8LI8:8LI8
java.lang.IllegalStateException: Session is acquired by 1 clients
at java.base/jdk.internal.foreign.MemorySessionImpl.alreadyAcquired(Unknown Source)
at java.base/jdk.internal.foreign.SharedSession.justClose(Unknown Source)
at java.base/jdk.internal.foreign.MemorySessionImpl.close(Unknown Source)
at org.cryptomator.jfuse.api@0.3.3/org.cryptomator.jfuse.api.Fuse.close(Fuse.java:191)
at org.cryptomator.frontend.fuse@2.0.3/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder$LinuxFuseMountedVolume.unmount(LinuxFuseMountProvider.java:134)
at org.cryptomator.desktop@1.7.2/org.cryptomator.common.vaults.Vault.lock(Vault.java:169)
at org.cryptomator.desktop@1.7.2/org.cryptomator.ui.lock.LockWorkflow.lock(LockWorkflow.java:63)
at org.cryptomator.desktop@1.7.2/org.cryptomator.ui.lock.LockWorkflow.retryOrCancel(LockWorkflow.java:73)
at org.cryptomator.desktop@1.7.2/org.cryptomator.ui.lock.LockWorkflow.lock(LockWorkflow.java:66)
at org.cryptomator.desktop@1.7.2/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:57)
at org.cryptomator.desktop@1.7.2/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:34)
at javafx.graphics@19.0.2.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
