Cryptomator Roadmap Mid 2019
We would like to take a more regular look at our roadmap to publicly document the past, present, and future developments of Cryptomator. Unlike before, we’re also going to have a look at the roadmaps of our mobile apps.
This is a companion discussion topic for the original entry at https://cryptomator.org/blog/2019/07/21/roadmap_en.html
iOS file integration is a great add-on. I tried to create the same extension (link below) and froze the project after coming to know the limitation of iOS files extension. Looks like third party files extension has memory limit of 15mb. When I tired to access files using my code, the decryption ran over 15mb and quit. Are you guys planning to change the decryption techniques for Cryptomator? I would love to know the progress you guys are making!
My code base: https://github.com/cestum/cator
can you publish an update about the already finished tasks from your 2019 roadmap?
For me the possibility for using Google Team drives is still important, what about your plan here?
Thx
Hi there, what about Upload of directories (recursive)?
Please can you let me know when do you think to work on it?
Thank you
Any update on the document provider feature on android?
