Cryptomator on my mac is not possible to copy folder including subfolder
Hi there,
unfortunately my cryptomator does creat an unknown error when copying a folder including subfolder to the cryptomator drive. There will be created an empty folder and there is error. I am using fuse.
how can I solve this issue?
Hi rationalchoice,
i had the same issue, when I initially was loading my Crytomator Vault with data. The “file is locked” or “you are not allowed to operate..” error message drove me crazy.
I could fix it with using the normal copy and paste function from macOS.
Instead i used the opensource software FreeFileSync. I installed the software mainly for the compare function. But i quickly found out, that it can not only compare but also copy and compare whole structures. I used the mirror function to move stuff from my source folders (cloud) into the vault - i move about 20.000 files - no error. I made sure that my files where available offline before.
For the inital vault load that was feasable. But i hope i dont run into the same issue again, for daily copy & paste tasks. Because the “FreeFileSync” tool is a GUI nightmare.
Cheers
Yep, I encountered the same issue. Switched to using MacFuse after trying Fuse-T and WebDav, but it’s very inconvenient that this happens so often. I frequently encounter “An unexpected error occured (error code -8058)” when using copy and paste directly in Finder.
