Hi, I have just installed Cryptomator on two computers. When I come to open the crypt on the second computer (I am using MEGA cloud, it says: Vault already initialized, but it has not opened.
If you can help, I’d be grateful,
Thanks!
Thanks!
Please enable debug mode, repeat the operation and upload log file here. Thx
22:11:23.423 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.3 on Windows 8.1 6.3 (amd64)
22:11:23.838 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
22:11:23.932 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:11:24.303 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
22:11:24.409 [JavaFX Application Thread] INFO org.eclipse.jetty.util.log - Logging initialized @-1ms to org.eclipse.jetty.util.log.Slf4jLog
22:11:24.450 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
22:11:24.471 [JavaFX Application Thread] INFO o.e.jetty.server.AbstractConnector - Started ServerConnector@f653640{HTTP/1.1,[http/1.1]}{127.0.0.1:42427}
22:11:25.475 [pool-4-thread-1] INFO o.c.ui.controllers.WelcomeController - Current version: 1.3.3, lastest version: 1.3.3
22:11:31.413 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:11:58.922 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\MA\AppData\Roaming\Cryptomator\keychain.json
22:11:59.808 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:12:08.189 [pool-4-thread-1] INFO org.eclipse.jetty.server.Server - jetty-9.4.7.v20170914
22:12:08.225 [pool-4-thread-1] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@585488a7{/,null,AVAILABLE}
22:12:08.226 [pool-4-thread-1] INFO org.eclipse.jetty.server.Server - Started @-1ms
22:12:08.226 [pool-4-thread-1] INFO o.c.frontend.webdav.WebDavServer - WebDavServer started.
22:12:08.292 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - DefaultSessionIdManager workerName=node0
22:12:08.292 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - No SessionScavenger set, using defaults
22:12:08.293 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - Scavenging every 600000ms
22:12:08.305 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
22:12:08.305 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
22:12:08.306 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
22:12:08.306 [pool-4-thread-1] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@242cb5e4{/irnIu36SQmXT/Crypt,null,AVAILABLE}
22:12:08.306 [pool-4-thread-1] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /irnIu36SQmXT/Crypt
22:12:08.362 [pool-4-thread-1] INFO o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/irnIu36SQmXT/Crypt using org.cryptomator.frontend.webdav.mount.WindowsMounter
22:13:11.924 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:14:45.147 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:14:45.965 [pool-4-thread-4] INFO o.c.ui.controllers.WelcomeController - Current version: 1.3.3, lastest version: 1.3.3
22:14:49.817 [JavaFX Application Thread] INFO o.e.j.server.handler.ContextHandler - Stopped o.e.j.s.ServletContextHandler@242cb5e4{/irnIu36SQmXT/Crypt,null,UNAVAILABLE}
22:14:49.817 [JavaFX Application Thread] INFO o.c.f.w.s.WebDavServletController - WebDavServlet stopped: /irnIu36SQmXT/Crypt
22:14:49.842 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\MA\AppData\Roaming\Cryptomator\keychain.json
22:15:08.767 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
22:15:08.767 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
22:15:08.767 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
22:15:08.768 [pool-4-thread-4] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@37a5b33a{/irnIu36SQmXT/Crypt,null,AVAILABLE}
22:15:08.768 [pool-4-thread-4] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /irnIu36SQmXT/Crypt
22:15:08.777 [pool-4-thread-4] INFO o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/irnIu36SQmXT/Crypt using org.cryptomator.frontend.webdav.mount.WindowsMounter
22:15:16.600 [JavaFX Application Thread] INFO o.e.j.server.handler.ContextHandler - Stopped o.e.j.s.ServletContextHandler@37a5b33a{/irnIu36SQmXT/Crypt,null,UNAVAILABLE}
22:15:16.601 [JavaFX Application Thread] INFO o.c.f.w.s.WebDavServletController - WebDavServlet stopped: /irnIu36SQmXT/Crypt
22:15:16.620 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\MA\AppData\Roaming\Cryptomator\keychain.json
22:15:23.440 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\MA\AppData\Roaming\Cryptomator\settings.json
22:15:24.203 [pool-4-thread-4] INFO o.c.ui.controllers.WelcomeController - Current version: 1.3.3, lastest version: 1.3.3
22:15:25.518 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\MA\AppData\Roaming\Cryptomator\keychain.json
22:15:30.244 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
22:15:30.244 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
22:15:30.244 [pool-4-thread-4] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
22:15:30.244 [pool-4-thread-4] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@324aba47{/irnIu36SQmXT/Crypt,null,AVAILABLE}
22:15:30.245 [pool-4-thread-4] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /irnIu36SQmXT/Crypt
22:15:30.258 [pool-4-thread-4] INFO o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/irnIu36SQmXT/Crypt using org.cryptomator.frontend.webdav.mount.WindowsMounter
22:15:39.645 [pool-4-thread-4] INFO o.c.ui.controllers.WelcomeController - Current version: 1.3.3, lastest version: 1.3.3
22:17:35.059 [JavaFX Application Thread] INFO o.e.j.server.handler.ContextHandler - Stopped o.e.j.s.ServletContextHandler@324aba47{/irnIu36SQmXT/Crypt,null,UNAVAILABLE}
22:17:35.059 [JavaFX Application Thread] INFO o.c.f.w.s.WebDavServletController - WebDavServlet stopped: /irnIu36SQmXT/Crypt
22:17:35.079 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\MA\AppData\Roaming\Cryptomator\keychain.json
22:17:51.386 [pool-4-thread-5] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
22:17:51.386 [pool-4-thread-5] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
22:17:51.386 [pool-4-thread-5] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
22:17:51.386 [pool-4-thread-5] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@e50e8a8{/irnIu36SQmXT/Crypt,null,AVAILABLE}
22:17:51.387 [pool-4-thread-5] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /irnIu36SQmXT/Crypt
22:17:51.397 [pool-4-thread-5] INFO o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/irnIu36SQmXT/Crypt using org.cryptomator.frontend.webdav.mount.WindowsMounter
Mhm, I don’t see anything unusual. Maybe someone else?
