Cryptomator 1.5.14 has stopped opening on my fresh install of OSX. I have FUSE installed. When I try to launch it from terminal, I get the following error:
Error opening "/Applications/Cryptomator.app/Contents/Contents/app/Cryptomator.cfg" file: No such file or directory
Your Cryptomator application is missing an important file. A reinstallation should fix this.
A followup question would be, why this file is missing, because it is installed with Cryptomator inside the installation folder.
I had the same error-message, but on a Windows PC (Window 10, Cryptomator 1.6.5). Re-installing Cryptomator solved the problem (the repair-option during the installation-process did not…). But what really irritates me is that this file was missing at all. I didn’t touch the folder and really don’t know, why/how it was deleted…
