Cryptomator not showing dropbox option
I have recently bought Cryptomator on Android and I have also installed in a linux OS here (PopOS). I have also installed dropbox desktop app.
Problem is in cryptomator when trying to create a vault, the dropbox option are not showing.
Any possible reason why?
dropbox status
/usr/bin/dropbox:614: DeprecationWarning: isSet() is deprecated, use is_set() instead
if self.stop_event.isSet(): break
Up to date
Welcome to the Cryptomator Community, :slightly_smiling_face:
What is your Dropbox folder path? Cryptomator only checks the Dropbox default (~/Dropbox or ~/Dropbox (_Your Teamname_)).
If your dropbox folder path differs, you have to select it with the “custom location” option.
Only ~/Dropbox
So, it doesnt really matter to have it customly selected, as long it’s a folder within ~/Dropbox?
I wasnt sure if the integration had more than just selecting a folder.
It basically only the folder selection. No matter if you choose „custom folder“ or the provider.
It almost make integrations pointless. Other than if users dont know the folder location.
Thanks.
That’s exactly the point of it.
