Cryptomator in quickaccess
I’m running v1.15.1 and after disabling “Add unlocked vaults to the quick access area” it still shows up in quick access, even when the vault is locked. Every time I mount the vault new icon appears and I only have one vault mounted. I have rebooted numerous times.
Thank you!
Nirav
Probably duplicate of Drives multiplying in Explorer after unlocking of vault
Is there a fix for it? or is it a bug?
Or better, see [Windows] latest version of Cryptomator keeps adding shortcuts to File Explorer - #4 by infeo
