Is there a possibility to link a vault in IceDrive?
Hey and welcome in the community !
According to their docs IceDrive does support WebDav so yes, it is compatible: https://icedrive.net/help/account/does-icedrive-support-webdav
If you create a new cloud connection with the following URL and your credentials you should be fine: https://webdav.icedrive.io/
I’ve been able to create a vault with the Android app on icedrive via webdav (ive tested on 1.50beta2), and its accessible from the desktop. However I can not create vaults from the desktop release candidates via webdav or the windows client.
I Haven’t spent much time on it, as i only picked up an icedrive account yesterday on the Sumo deal. 2 possible issues that i think is affecting creating vaults from desktop.
Icedrive’s webdav will not let you create an empty 0byte file. - the file just vanishes or gives access denied error. - Cryptomator fails on vault creation with “read only file system” - so i’m presuming as part of the file length test a 0 byte file might be created???
Possibly does not support the max length of vault format 7? Yet to confirm.
Cryptomator doesn’t create 0-byte files (in the ciphertext directory), so this is not the problem.
The problem isn’t caused by the cloud service, but rather by Windows’ WebDAV-Client, which doesn’t support long paths that can occur with vault format 7.
I’ll write a detailed support article on this issue.
Hereby confirmed, however not the server’s fault.
However only paid plans at IceDrive currently support WebDav - there is no support in the free account
