Good morning, I have a drive in a Google Drive that I have created from my iOS and then from my PC I would like to access with Google Drive desktop.
So I can access from my Pc to the folder and when I click to the file cryptomator I can have from the cryptomator the possibility to unlock it but after entering the pwd I have an error:
org.cryptomator.cryptolib.api.UnsupportedVaultFormatException: Tried to open vault of version 999, but can only handle version 7
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:118)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:109)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:40)
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:41)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:329)
at org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:121)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:126)
I have the portable version installed from a USB key from where I have created another cryptomator folder.
Thanks
