Cryptomator + iCloud advanced data protection
Hi All
I have just signed up to this forum. I have a question. Do you foresee any incompatibility between Cryptomator and iCloud + ADP(advanced data protection)?
In that case iCloud is E2EE and I do not know if it may interfere with Cryptomator mechanisms. I will greatly appreciate any help: I just upgraded to an M2 MAC with Sonoma after years of use with an old intel MAC; by the way: should I always prefer FUSE-T Vs WebDav on Silicon MACs?
Thanks, best regards
Hi All
Sorry for bothering you, again. Just checking if any of you is using Cryptomator with iCloud + ADP; I wanted to enable ADP on my present iCloud, but I do not want to scramble my existing Cryptomator vaults.
Any feedback?
Thanks for your support
