I (want to) use Cryptomator for LaTeX edditing, but the process freezes as soon as I want to compile the file.
I am using :
- cryptomator linux desktop (ubuntu 16.04)
- the folder in question is sinking to owncloud
- Any LaTeX editor (texstudios, texmaker, texwork all the same problem)
I open my cryptomator vault containing my .tex files and open them using my LaTeX editor. As soon as I click “compile” or “run and view” I see that cryptomator is decrypting data (green spike), but then the LaTeX editor freezes.
If i do:
ps aux | grep "name-of-my-latex-editor"
I see some processes that I dont succeed to kill, and I have to reboot my computer in order to use the LaTeX editor again. If I want to close the vault i says “Ejecting drive failed”. If I try to eject the vault manualy (in the Files and click the unmount buttom) it sais that "Volume is bussy, one or more processes are using it"
The processes listen are four times the same process
pdflatex
/usr/bin/pdflatex-synctex=1 -interaction=nonstopmode example.tex
The process which I cant kill with “sudo -9 kill XXXX” is listed below
molly 5743 14.6 3.1 2378028 255316 ? Sl 16:59 0:06 texstudio /run/user/1000/gvfs/dav:host=localhost,port=42427,ssl=false,prefix=%2FfU_NyFzETJDn%2FOwncloud_Cryptomator/latex/example.tex
molly 5810 0.0 0.0 14228 968 pts/2 S+ 16:59 0:00 grep --color=auto texstudio
This problem does not occures when I copy past the .tex file to a place outside the cryptomator vault, so the problem is not part of the .tex files or the latex editor.
Any help would be appreciated. I find Cryptomator super awesome, and I promise I will donate if this ends up working well for me.
Cheers
