Hi guys, everything works fine with this setup. But before I fully commit to Cryptomator, I’d like to know how will the upgrade work in the future:
Will the Vault format be upgraded? Or will I have to create a new vault, using the new version of Cryptomator, download all my files and then re-upload them into the new vault?
I’ve also seen a huge number of old posts regarding the encryption keys that, with the old version of the vault, are stored directly in Dropbox. What happens with these keys when one upgrades?
If you open an old vault format with a newer cryptomator app, you will be asked to start the migration process. This should not download/upload all your files
Don’t know where you read this, but the encryption key is stored nowhere. That would be a huge security issue. I guess you mean the masterkey file (which is not the encryption key). As far as I know the masterkey file is unchanged when you migrate from vault format 7 to 8.
An example is this long-winding argument about the masterkey.cryptomator file where the penultimate post says “It’s already under development and will be a feature of vault format 8 coming with version 1.6”. And elsewhere, I can’t recall where now, it was mentioned that this change was necessary for the creation of the Cryptomator Hub. So I assume that something will happen with the masterkey.cryptomator file during the upgrade, so I just want to know what to expect or possibly be careful about.
Yep, so I was right with my assumption that you mixed up encryption key with masterkey file.
In simple words: the encryption key is generated by the key in your masterkey file AND your password. That’s why the file is still in the cloud (and available everywhere you want to open that vault) and still no one can decrypt your vault just with the masterkey.
Detailes here: Security Architecture — Cryptomator 1.7.0 documentation
But as people wanted to have an option to store this file somewhere else, and this this feature was introduced later on.
But as far as I know this feature did not change the masterkey content. Just the way the path to it is handled.
Thank you Michael. So it seems like the future upgrade should be pretty painless. The vault format will be migrated automatically and unless I desire to keep the masterkey.cryptomator file elsewhere, I do not need to worry about it either. Great!
