Hello, I want Cryptomator to NOT automatically lock the safe when inactive. Where can I set this?
Thanks for the help, Jens
It’s in the options for the vault itself. You have to lock the vault you want to make the change to and then click “Vault Options”.
The setting is called “Lock when idle for ___ minutes”.
Perfect, thank you very much, I found it.
best regards, Jens
