Cryptomator and SD Card?
I’m planning to buy Cryptomator.
Is it possible to password protect the micro sd card or any file with Cryptomator ?
Or is it only for cloud services ?
You don’t encrypt the entire SD card, but you can put a cryptomator vault (encrypted) onto your micro SD card and put any file inside that vault.
And no, that doesn’t require the cloud. Although many people put files on the cloud to provide the advantage that you can access them from many different devices.
On Android, some apps cannot readily access the files in an unlocked vault without exporting them outside of the vault first. On PC it’s more flexible, all the apps on your pc can access files directly in the unlocked vault without exporting them.
