I would like to try cryptomator on different clouds, e.g. on Google Drive and GMX Cloud. Is it possible on GMX Cloud without any problems or is it better to use the GMX Tresor (Safe?) there?
Thank you.
Thank you.
You can use GMX storage with Cryptomator desktop and the mobile apps (mobile via WebDAV acces).
You can’t use it with the GMX Tresor because this Tresor does need its own apps to access and decrypt.
BTW: GMX Tresor is based on Cryptomator.
