Hi beautiful Cryptomating People ![]()
I use CM on Ubuntu 22.04LTS, OS regularly updated, and I cannot access to one of my vaults. The others are accessible.
The app gives me this message below, and in addition the link to the solution in the appâs error âlook up solutionâ window is inaccessible (click not active).
Can you help?
have a good day!
Error Code 6HCL:2GTN:8714
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.frontend.fuse@4.0.0-beta5/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:128)
at org.cryptomator.desktop@1.11.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:138)
at org.cryptomator.desktop@1.11.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.11.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
at javafx.graphics@20.0.2/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.jfuse.linux.amd64@0.6.3/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:36)
at org.cryptomator.jfuse.api@0.6.3/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:126)
at org.cryptomator.frontend.fuse@4.0.0-beta5/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:125)
... 13 more
