Thatâs not possible yet but weâll look into it during the beta. We already laid the groundwork for that but just havenât tested/implemented it explicitly.
Thanks for the update!
Itâs great to have this feature. It makes no sense to constantly download the same data (especially over cellular), each time you access that data.
Nextcloud has such feature.
Is there a possibility to âlockâ a Vault within the Files App?
It looks like that the Vault is always unlocked.
For sure my Devices are protected with Code/Finger/Face, but I feel uncomfortable when my Vaults are unlocked within the Files App.
Thx
Not yet. But it will come very soon, this is currently our roadmap for the next update:
- Unlock via Touch ID / Face ID
- (Manual) Lock
Auto-Lock(Edit: Postponed to later version)
quick bug in beta version:
I have a file in a vault. I can open it in desktop app and on iOS cryptomator 1.6. On 2.0, I can see only file name , but itâs gray and I canât open it. Clearly a bug in 2.0.
Please write a bug report so that we can have a look, thank you!
I got Cryptomator 2.0.0 (502) via Testflight on iOS and am stuck in an endless circle. I start Cryptomator 2.0.0, select âAnderer Datei-Anbieterâ, âTresorordner auswĂ€hlenâ and choose an existing Cryptomator folder in my iCloud Drive, provide the password and see screen1. The vault is locked, but I do not see any possibility to unlock the vault. The only option is to choose âApp âDateienâ öffnenâ. That leads to screen2. When choosing âAuthenticateâ, I get this screen. âCryptomator öffnenâ brings me back to screen1.
Either I am missing something or it might be related to having installed an iOS beta version on my iPhone (15.0 19A5318f).
Up until here, it actually looks as expected.
This is actually unexpected, it should show an âunlockâ screen.
Could you please go the Cryptomator settings and tap âSend Log Fileâ? E.g., you can send it to me via a direct message or post all information as a bug report.
Just wanted to add, that I see the same behavior on the latest iPadOS 15 Beta. Happy to send logs, should you still need them.
Super happy with this
All my office files are opened n âread-onlyâ mode.
How can I edit them from the file explorer, ie, not read-only mode?
Thanks
@hoehenunterschied @stephan1 Just wanted to let you know that this should be fixed now with the latest version. It was indeed a bug on iOS 15.
@rgallego Do you have the Office apps installed? Should work with them.
@tobihagemann yes I do⊠I have all the office apps installed. The files open fine but I just cant edit them unless I make a copy.
Update:
Re-added my vault and all is looking better. The first time the file is downloaded it will be in read-only mode. But if I close Word or Excel and open again it will work.
I can live with that
Mega thanks!
One question about the iOS Version in general, does Cryptomator store the key file also in the cloud? Or is it always only on the device? Means, even if someone would have access to the cloud AND has the password, decryption is impossible?
The encrypted masterkey file is stored in the cloud: Why is the masterkey stored in the cloud?
No, if someone has access to the cloud and has the password, decryption is possible. Thatâs basically the ânormalâ use case for using Cryptomator on multiple devices.
Thatâs a bit a pity, as there are solutions to synchronize the apps without the key file in the cloud, but thank you for answering.
Keeping the key in the cloud has zero impact on attacks, provided that your password is strong. Itâs encrypted.
Itâs not pity.
Thatâs 100% clear. Anyway the protection is completely lost even with the strongest password if itâs captured on a whatever attack.
If your device is compromised, e2ee is pointless in the first place.
Cryptomatorâs security target is all about using an untrusted storage space with trusted devices.
Hi guys, fantastic work!
Iâm currently testing v2.0.0(451) on iOS 15.0.2
The user experience has significantly improved, great job on that. New features like google drive apps integration are awesome, however, I noticed some small probably just UX issues there:
I added a vault for google drive with the following steps:
- Tab the plus button.
- choose Create New Vault.
- select Google Drive & complete google auth.
- select Create New Folder.
- choose
- create new password & create
- confirm the confirmation prompt.
The screen gets stuck at step 7 for sometime probably creating the vault on google drive and then eventually it moves forward. Not a big deal but itâd be nice to display a spinner or something similar to let the user know they should wait. Everything else was flaw less here
Then the next thing I tested was creating a vault using Other File Providers feature.
When you tab Select Storage Location, only iCloud Drive and On My iPhone options are selectable. Iâm not sure if itâs something to do with permissions from the file providers or iOS itself but I checked the settings everywhere and didnât find a clue. I wish there was a way to effectively choose the storage location from file list of providers. It can also be totally me not using the app properly, please correct me if thatâs the case.
Here is an image about storage locations and as you see only local iOS storage and iCloud Drive are selectable.
Still testing the other aspects such as accessibility and encryption.
Cheers
