error: There was a problem connecting to the server “localhost”.
/etc/hosts shows the required entries
How to correct the error. thanks
Please try the workaround described here: https://github.com/cryptomator/cryptomator/issues/1310#issuecomment-681932567
Workaround:
- Select the vault in Cryptomator.
- Press “Vault Options”.
- Select the tab “Mounting”.
- “Drive Name” is probably empty, give it some name.
