I’m looking for the throughput graph when I/O files. Was this feature removed?
Also, I’m recreating my vault instead of migrating. Where can I find a list of features in the new vault version 7?
The graph was removed. But you can still have a look at the actual values in the right lower corner of the app window. (Make sure you have the vault selected that you want to check)
In addiction you can read about the changes in the change log
There is an open feature request to re-add it:
