Creating Virtual mount drive
Hello Everyone,
I need small help. I want to create one master vault (as virtual drive) and inside that I want to mount my cloud drives and local vault.
So, I will unlock master drive then I can unlock all other drives inside that master drive using custom mount path.
will it be possible?
When I am doing same it is mounting inside drive and but for other drive inside that shows empty after unlock. And I can see warning of Timout occurred,
Thanks in advance for help.
Hi. Please do not create a vault inside a vault. You gain not more security from it. Instead you’ll create performance issues, that might me the reason for your Timeouts.
