I use CrashPlan for continuous backups. I’d like to Crashplan to backup my Vault when it’ unlocked. Currently, CrashPlan doesn’t see the Vault’s mounted drive letter. The Vault appears in File Explorer as My_Vault (\cryptomator-vault@42427\bE_g2_vc8EvI) (Z:) . I’m running Windows 11 Pro. Thanks for any help.
Please check your vault setting. Based on your vault path currently WebDAV is used as volume type. Switch that to WinFSP.
If the virtual drive is still not seen by Crashplan, you can mount the vault as a folder instead of a virtual drive. To do that create an empty folder and select this folder in the vault options as mount point. The folder has to be empty if you want to use it as mountpoint.
