Hey everyone,
I’m probably missing something obvious here, so bear with me
I’ve got the cryptomator app installed on a moto g5 with lineageOS 14.1 and tried both of the approaches below with the default file manager and also with fx file manager, but I failed to copy a folder into a vault (i.e. encrypt it).
approach: From within the cryptomator app and an unlocked vault I selected “upload file”, but when navigating through the file manager I’m only able to select file (as the name suggests) but can’t upload/encrypt an entire folder with contents.
approach: From within one of the above mentioned file managers and clicking and holding on an item, I can only get the share->cryptomator option for files. Again, I can’t select a folder to be uploaded/encryted.
Is there anything, that I’m missing or is this a feature that is not implemented (yet) in this otherwise great app?
Thanks and regards,
C
