Context Menu in System Tray @ UI Scaling and High Resolution Screen
Hi folks,
just a FYI. Not a big thing, but maybe something which can easily be fixed.
I run Cryptomator on my Surface Pro 4 which has a native screen resolution of 2736x1824.
Right-Clicking on the Cryptomator icon in the system try opens the context menu, which is a bit… small :slight_smile:
See screenshot below!
Cheers
Phil
HiDPI support for Windows and Linux should be working as soon as we build Cryptomator using Java 9. This is a high priority task, but we depend on certain libraries that are not yet ready.
8 years later, still not fixed? I’m using Windows 11 with a 4K screen and the UI is really tiny.
Hello? Is there anybody out there? Why can’t this be fixed?
