Hi, I just installed the CM App on my Android devices and tried to connect with my Gdrive. Unfortunately this failed. The device becomes very slowly and runs in a circle with trying to get access and Gdrive access control request. It is not possible to finish this procedure. The device will have an automatic restart after a long time (~10 minutes). I tried this on different Android devices, but this behavior is still the same. Gdrive in general works on the devices. Any recommendations? Thanks and best regards. Jutl
Issue was solved by temporarily disabling the option “App blockieren, wenn verdeckt”.
