I keep getting confused by the path naming. In Cryptomator I set up Folder1/Folder2 but then in iCloud the path ends up being Folder2/Folder1. Am I doing something wrong?
Thanks
Morgs
Thanks
Morgs
Not sure if I understand you correctly, but you should not be able to „see“ any of your folder names in iCloud, as the names should be encrypted.
