I have a vault where I use to have about 29k Files and about 2.7K folders. Recently I decided to zip many files together to reduce the number of files. I now have 60 files and 26 Folders in the un-encrypted state.
However the encrypted vault now has about 800 files and still about 2.7k folders. There seems to be too many files leftover. So I checked and see that most of the files are in the “m” directory with .lng extension and also I have many (hundreds) of empty folders in the “d” directory.
After zipping the files, most of the zip files now have short names and am surprise to see so many .lng extensions in the “m” directory. I now only have 60 files, so 800 .lng files seem to be leftover from the previous files and structure
Is there a way to clean up the file and folder structure without corrupting the vault in any way?
Can I delete all the empty folders in the “d” directory with any problem?
It would be good if there was a feature built into to clean up the vault structure.
thanks
