I am on a PC with Windows 10 installed. When I created my first vault I picked a folder location in One Drive. I would like to change the name of that folder, and of course, I could do that simply by right clicking it and then renaming. However, I don’t want to do that if it causes problems. Will it cause issues with my vault?
No. The vault does not depend on the folder name. You only have to add it to Cryptomator again, since Cryptomator identifies vaults with their path on the system. (which changes if you rename the folder)
