Can't lock files (via 'Get Info') on macOS Big Sur when using Cryptomator
I don’t know if anyone else has also been having this issue, but I can’t lock files on macOS which are located inside a Cryptomator’s vault. If I check the ‘Locked’ checkbox on the “Get Info” window, nothing changes to the file, and it remains editable. If I open the ‘Get Info’ again, the checkbox is unchecked.
I’m using Cryptomator 1.6.10 (mounting vaults via macFuse) on macOS BigSur 11.6.7.
Any ideas?
Thanks!
