Can't delete from vault list
Hello, I am new to this forum. Unfortunately, I can’t find a solution to my problem. I am trying to remove various vault entries from the list, but it’s not working. When I click on ‘remove’ or ‘remove from vault list,’ nothing happens…
I have the same problem on my computer. Maybe it’s a problem since the last update?
This problem is already reported on the offical issue tracker, see
We found the cause, it is a localization issue.
Workaround: Set the app language to english.
Hi, now it works fine !
Thank you
