I keep my SSH keys in Cryptomator, but now that I’ve upgraded to 1.40 and switched to Fuse mount I’m getting the following error:
@ WARNING: UNPROTECTED PRIVATE KEY FILE! @
Permissions 0644 for ‘some_key’ are too open.
It is required that your private key files are NOT accessible by others.
This private key will be ignored.
Looking at files in the mounted volume in ~/Library/Application Support/Cryptomator/VaultName2348fasf/
They are all group+world readable. Can I specify mounting to be ug-rw and only u+rw ?
Or is there another workaround to allow SSH keys within the cryptomator volume to work?
Thank you.
